The Bayesian ABEL Bound on the Mean Square Error - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
This paper deals with lower bound on the Mean Square Error (MSE). In the Bayesian framework, we present a new bound which is derived from a constrained optimization problem. This bound is found to be tighter than the Bayesian Bhattacharyya bound, the Reuven-Messer bound, the Bobrovsky-Zakai bound, and the Bayesian Cramér-Rao bound.
RFLR06.pdf (132.46 Ko) Télécharger le fichier
inria-00444825 , version 1 (07-01-2010)
Alexandre Renaux, Philippe Forster, Pascal Larzabal, Christ Richmond. The Bayesian ABEL Bound on the Mean Square Error. ICASSP 2006 - 31th IEEE International Conference on Acoustics, Speech and Signal Processing, 2006, Toulouse, France. ⟨10.1109/icassp.2006.1660577⟩. ⟨inria-00444825⟩
111 Consultations
418 Téléchargements
