Capacity of wireless mesh networks: determining elements and insensible properties - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2010
Anis Ouni
Fabrice Valois
The capacity of a multi-hop wireless network is the traffic payload that it can transport. This is a prominent quality of service issue, particularly in the highly constrained settings of 802.11 wireless mesh network. In this paper, we consider two complementary definitions of the capacity. A network-wise capacity is defined as the sum of the upload traffic, and a flow-wise capacity highlighting the unfairness among traffic flows. We study the behavior of these capacities face to several parameters: routing protocols, number and location of gateways bridging the network to the Internet, and the physical network topology. Thorough simulations highlight the insensitivity of the capacity face to these parameters while it is directly related to the congestion around the gateway. Furthermore, we show that if the number of gateways increases, the capacity tends to a maximum boundary.
RR-7171.pdf (322.22 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
inria-00444891 , version 1 (07-01-2010)
  • HAL Id : inria-00444891 , version 1
Anis Ouni, Hervé Rivano, Fabrice Valois. Capacity of wireless mesh networks: determining elements and insensible properties. [Research Report] RR-7171, INRIA. 2010. ⟨inria-00444891⟩
189 Consultations
750 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
