Predictive Runtime Code Scheduling for Heterogeneous Architectures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Heterogeneous architectures are currently widespread. With the advent of easy-to-program general purpose GPUs, virtually every recent desktop computer is a heterogeneous system. Combining the CPU and the GPU brings great amounts of processing power. However, such architectures are often used in a restricted way for domain-specific applications like scientific applications and games, and they tend to be used by a single application at a time. We envision future heterogeneous computing systems where all their heterogeneous resources are continuously utilized by different applications with versioned critical parts to be able to better adapt their behavior and improve execution time, power consumption, response time and other constraints at runtime. Under such a model, adaptive scheduling becomes a critical component. In this paper, we propose a novel predictive user-level scheduler based on past performance history for heterogeneous systems. We developed several scheduling policies and present the study of their impact on system performance. We demonstrate that such scheduler allows multiple applications to fully utilize all available processing resources in CPU/GPU-like systems and consistently achieve speedups ranging from 30% to 40% compared to just using the GPU in a single application mode.
inria-00445304 , version 1 (08-01-2010)
Victor J. Jiménez, Llu'Is Vilanova, Isaac Gelado, Marisa Gil, Grigori Fursin, et al.. Predictive Runtime Code Scheduling for Heterogeneous Architectures. HiPEAC 2009 - High Performance and Embedded Architectures and Compilers, Jan 2009, Paphos, Cyprus. ⟨10.1007/978-3-540-92990-1_4⟩. ⟨inria-00445304⟩
89 Consultations
0 Téléchargements
