Size-Based Flow Scheduling in a CICQ Switch
Dinil Mon Divakaran 1 Fabienne Anhalt 1 Eitan Altman 2 Pascale Primet 1
1 RESO - Protocols and softwares for very high-performance network
Inria Grenoble - Rhône-Alpes, LIP - Laboratoire de l'Informatique du Parallélisme
2 MAESTRO - Models for the performance analysis and the control of networks
CRISAM - Inria Sophia Antipolis - Méditerranée
Abstract : In the context of flow-aware networking, size-based (SB) scheduling policies have been shown to improve response times of small flows, without degrading the performance of large flows. But these differentiating policies are designed for Output-queued (OQ) switch architecture, which is known to have scalability issues. On the other hand, the buffered-crossbar (BX) switch architecture is currently being pursued as a potential next-generation scalable switch architecture. This work looks into the problem of performing SB scheduling in BX switches. In particular, the design goals, with respect to each output port, are (i) to transmit high-priority packet(s) as long as there is at least one present, and (ii) to respect the FIFO order among high-priority packets. In this direction, we propose a CICQ switches using a single PIFO queue at each crosspoint to schedule packets according to the priority assigned. pCICQ-1 switch uses a simple design to guarantee that packet-priorities are respected once they are in the crosspoint queues. But it does not maintain the FIFO order of high-priority packets, besides letting a bounded number low-priority packets to depart through an output, when there are one or more high-priority packets for the same output. To solve this, we propose an enhancement in pCICQ-2 switch, that uses a sequence controller to respect packet-priorities as well as arrival order for high-priority packets.
Type de document :
Rapport
[Research Report] RR-7183, INRIA. 2010
Liste complète des métadonnées
Littérature citée [15 références]  Voir  Masquer  Télécharger
https://hal.inria.fr/inria-00450054
Contributeur : Dinil Mon Divakaran <>
Soumis le : lundi 25 janvier 2010 - 11:09:40
Dernière modification le : samedi 21 avril 2018 - 01:27:31
Document(s) archivé(s) le : jeudi 18 octobre 2012 - 13:10:42
Fichier
RR-7183.pdf
Fichiers produits par l'(les) auteur(s)
  • HAL Id : inria-00450054, version 1
Collections
Citation
Dinil Mon Divakaran, Fabienne Anhalt, Eitan Altman, Pascale Primet. Size-Based Flow Scheduling in a CICQ Switch. [Research Report] RR-7183, INRIA. 2010. 〈inria-00450054〉
Métriques
Consultations de la notice
387
Téléchargements de fichiers
308
