BlobSeer: Efficient Data Management for Data-Intensive Applications Distributed at Large-Scale - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Gabriel Antoniu
Luc Bougé
Large-scale data-intensive applications are a class of applications that acquire and maintain massive datasets, while performing distributed computations on these datasets. In this context, a a key factor is the storage service responsible for the data management, as it has to efficiently deal with massively parallel data access in order to ensure scalability and performance for the whole system itself. This PhD thesis proposes BlobSeer, a data management service specifically designed to address the needs of large-scale data-intensive applications. Three key design factors: data striping, distributed metadata management and versioning-based concurrency control enable BlobSeer not only to provide efficient support for features commonly used to exploit data-level parallelism, but also enable exploring a set of new features that can be leveraged to further improve parallel data access. Extensive experimentations, both in scale and scope, on the Grid5000 testbed demonstrate clear benefits of using BlobSeer as the underlying storage for a variety of scenarios: data-intensive grid applications, grid file systems, MapReduce datacenters, desktop grids. Further work targets providing efficient storage solutions for cloud computing as well.
PID1121303.pdf (69.97 Ko) Télécharger le fichier
inria-00457809 , version 1 (18-02-2010)
Bogdan Nicolae, Gabriel Antoniu, Luc Bougé. BlobSeer: Efficient Data Management for Data-Intensive Applications Distributed at Large-Scale. IPDPS '10: Proceedings of the 24th IEEE International Symposium on Parallel and Distributed Processing: Workshops and Phd Forum, Apr 2010, Atlanta, United States. pp.1-4, ⟨10.1109/IPDPSW.2010.5470802⟩. ⟨inria-00457809⟩
306 Consultations
376 Téléchargements
