Performance Evaluation of the SERENA Algorithm to SchEdule RoutEr Nodes Activity in Wireless Ad Hoc and Sensor Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Saoucene Mahfoudh
  • Fonction : Auteur
  • PersonId : 844868
Pascale Minet
In wireless ad hoc and sensor networks, an analysis of the node energy consumption distribution shows that the largest part is due to the time spent in the idle state. This result is at the origin of SERENA, an algorithm to SchEdule RoutEr Nodes Activity. SERENA allows router nodes to sleep, while ensuring end-to-end communication in the wireless network. It is a localized and decentralized algorithm assigning time slots to nodes. Any node stays awake only during its slot and the slots assigned to its neighbors, it sleeps the remaining time. Simulation results show that SERENA enables us to maximize network lifetime while increasing the number of user messages delivered. We quantify the slot reuse and evaluate the impact of the frame size on network performance. We then study how to dimension buffers at the router nodes. Finally, we show how SERENA improves the node energy consumption distribution and maximizes the energy efficiency of wireless ad hoc and sensor networks.
Fichier non déposé
inria-00459499 , version 1 (24-02-2010)
  • HAL Id : inria-00459499 , version 1
Saoucene Mahfoudh, Pascale Minet. Performance Evaluation of the SERENA Algorithm to SchEdule RoutEr Nodes Activity in Wireless Ad Hoc and Sensor Networks. AINA 2008, Mar 2008, Ginowan, Japan. ⟨inria-00459499⟩
54 Consultations
0 Téléchargements
