Investigating Data Broadcast Performance in Mobile Ad Hoc Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2002
In this paper, we investigate broadcasting in Mobile Adhoc NETworks (MANETs). We define broadcasting as being the process of delivering one packet, originated at one node, to (ideally) all other nodes in the MANET. We present specific problems related to broadcasting in MANETs, as well as four broadcast protocols aimed at providing MANET-wide broadcast. Further, three protocol-independent modifications are presented. One aimed at ensuring that a broadcast packet traverses at least the ``shortest path'' to its destinations, and two aimed at increasing the fraction of nodes which receive a broadcast packet. Through simulation studies, we evaluate the performance characteristics of the broadcast protocols and generic modifications under different conditions.
wpmc2002a.pdf (87.59 Ko) Télécharger le fichier
inria-00471705 , version 1 (09-04-2010)
Thomas Clausen, Laurent Viennot, Tue Olesen, Nicolai Larsen. Investigating Data Broadcast Performance in Mobile Ad Hoc Networks. The 5th International Symposium on Wireless Personal Multimedia Communications (WPMC), Oct 2002, Honolulu, United States. pp.1-5, ⟨10.1109/WPMC.2002.1088283⟩. ⟨inria-00471705⟩
195 Consultations
181 Téléchargements
