Composition of Qualitative Adaptation Policies - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
In a highly dynamic environment, software systems requires a capacity of self-adaptation to the environ- ment and the user needs evolution, which increases the software architecture complexity. Despite most current execution platforms include some facilities for handling dynamic adaptation, current design methodologies do not address this issue. One of the requirement for such a design process is to describe adaptation policies in a composable and qualitative fashion in order to cope with complexity. This paper introduces an approach for describing adaptation policies in a qualitative way while keeping the compositionality of adaptation poli- cies. The basic example of a web server is used to il- lustrate how to specify and to compose two adaptations policies which handle respectively the use of a cache and the deployment of new data sources.
Chauvel08c.pdf (114.52 Ko) Télécharger le fichier
inria-00477536 , version 1 (29-04-2010)
Franck Chauvel, Olivier Barais, Isabelle Borne, Jean-Marc Jézéquel. Composition of Qualitative Adaptation Policies. 23rd IEEE/ACM International Conference on Automated Software Engineering - ASE'08, 2008, L'Aquila, Italy, Italy. pp.455 - 458, ⟨10.1109/ASE.2008.72⟩. ⟨inria-00477536⟩
213 Consultations
131 Téléchargements
