Design Methodology for a High Performance Robust DVB-S2 Decoder Implementation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The new Digital Video Broadcasting Satellite (DVBS2) standard is able to provide capacity gains of about 30% over the previous standard by using a powerfull Forward Error Correction (FEC) scheme based on very large LDPC codewords and BCH codes. The implementation of the DVB-S2 FEC decoder is a big challenge. The designer must deal with the overall design complexity and the decoding throughput in order to obtain a high decoding performance in terms of bit error rate (BER). We present in detail a complete design flow allowing a better understanding of the algorithm in terms of complexity, performance and its hardware implementation. We focus on complexity-performance trade-offs due to message quantizations and we compare its effects on several algorithm corrections used to check nodes for DVB-S2 decoding. The simulation results show that the best compromise between complexity and performance is obtained for the FOMS algorithm approximation.
Fichier non déposé
inria-00480723 , version 1 (04-05-2010)
  • HAL Id : inria-00480723 , version 1
Florent Berthelot, François Charot, Charles Wagner, Christophe Wolinski. Design Methodology for a High Performance Robust DVB-S2 Decoder Implementation. 13th EUROMICRO Conference on Digital System Design Architectures, Methods and Tools (DSD 2010), Sep 2010, Lille, France. ⟨inria-00480723⟩
100 Consultations
0 Téléchargements
