A Visual, Open-Ended Approach to Prototyping Ubiquitous Computing Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
By nature, ubiquitous computing applications are intimately intertwined with users' everyday life. This situation is challenging because it requires to make the development of applications accessible to end-users. Furthermore, ubiquitous computing consists of a variety of areas, including home automation and assisted living, raising a need for an open-ended approach. We present Pantagruel, a visual programming language that is end-user oriented. Our approach is open-ended in that Pantagruel integrates a language to describe a ubiquitous computing environment in the form of a taxonomy, defining the entities relevant to a given ubiquitous computing area. This description serves as a parameter to a sensor-controller-actuator development paradigm. The orchestration of area-specific entities is supported by high-level constructs, customized with respect to taxonomical information.
pantagruel-demo.pdf (444.73 Ko) Télécharger le fichier
inria-00484083 , version 1 (17-05-2010)
  • HAL Id : inria-00484083 , version 1
Zoé Drey, Charles Consel. A Visual, Open-Ended Approach to Prototyping Ubiquitous Computing Applications. Proceedings of the 8th IEEE Conference on Pervasive Computing and Communications (PERCOM'10), Mar 2010, Mannheim, Germany. ⟨inria-00484083⟩
Collections
CNRS INRIA INRIA2
158 Consultations
270 Téléchargements
