Viewpoints: a Framework for Object-Oriented Database Modelling and Distribution - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue CODATA Data Science Journal Année : 2005
The viewpoint concept has received widespread attention recently. Its integration into a data model improves the flexibility of the conventional object-oriented data model and allows one to improve the modelling power of objects. The viewpoint paradigm can be used as a means of providing multiple descriptions of an object and as a means of mastering the complexity of current database systems enabling them to be developed in a distributed manner. The contribution of this paper is twofold: to define an object data model integrating viewpoints in databases and to present a federated database system integrating multiple sources following a local-asextended- view approach.
dsj.pdf (228.16 Ko) Télécharger le fichier
inria-00485958 , version 1 (24-05-2010)
Fouzia Benchikha, Mahmoud Boufaida, Lionel Seinturier. Viewpoints: a Framework for Object-Oriented Database Modelling and Distribution. CODATA Data Science Journal, 2005, 4, pp.92-107. ⟨10.2481/dsj.4.92⟩. ⟨inria-00485958⟩
223 Consultations
302 Téléchargements
