Programming, Composing, Deploying for the Grid - Archive ouverte HAL Access content directly
Book Sections Year : 2006
Grids raise new challenges in the following way: heterogeneity of underlying machines/networks and runtime environments (types and performance characteristics), not a single administrative domain, versatility. So the need to have appropriate programming and runtime solutions in order to write, deploy then execute applications on such heterogeneous distributed hardware in an effective and efficient manner. We propose in this article a solution to those challenges which takes the form of a programming and deployment framework featuring parallel, mobile, secure and distributed objects and components.
ProgrammingDeployingComposingForTheGrid.pdf (493.67 Ko) Télécharger le fichier
Dates and versions
inria-00486114 , version 1 (25-05-2010)
Identifiers
Cite
Laurent Baduel, Françoise Baude, Denis Caromel, Arnaud Contes, Fabrice Huet, et al.. Programming, Composing, Deploying for the Grid. Cunha, Jose C.; Rana, Omer F. Grid Computing: Software Environments and Tools, Springer, pp.205 - 229, 2006, 978-1-85233-998-2. ⟨10.1007/1-84628-339-6_9⟩. ⟨inria-00486114⟩
184 View
187 Download
Share
