Accelerating Data Movement on Future Chip Multi-Processors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Moving data between cores on hardware coherent architectures suffers from memory latency and causes cache misses and o-herence traffic, which are obstacles to achieving high perform-ance. In this paper, we evaluate the potential for hardware opti-mization of message data transfer on chip multiprocessors with a combination of NAS parallel MPI benchmarks, Intel IMB MPI benchmarks, and a few microbenchmarks on a full-system simulator based on Simics and FeS2. We show that while pas-sive hardware driven by cores can reduce cache traffic, it pro-vides limited performance gains. We propose a data move-ment manager (DMM) that uses the on-chip coherence protocols to implement zero-copy message passing between separate ad-dress spaces and to remove synchronization and copy overheads from the processors. We also discuss methods for managing data placement in caches to reduce latency. We show that such a design shows substantial promise for both cache traffic reduc-tion and performance improvements.
Fichier non déposé
inria-00492860 , version 1 (17-06-2010)
  • HAL Id : inria-00492860 , version 1
Junli Gu, Rakesh Kumar, Steven S. Lumetta, Yihe Sun. Accelerating Data Movement on Future Chip Multi-Processors. IFMT'10 - Second International Forum on Next Generation Multicore/Manycore Technologies, Jun 2010, Saint Malo, France. ⟨inria-00492860⟩
Collections
IFMT10 ISCA2010
27 Consultations
0 Téléchargements
