Estimation problems for a class of impulsive systems
This paper deals with on-line identification of continuous-time systems subject to impulsive terms. Using a distribution framework, a scheme is proposed in order to annihilate singular terms in differential equations representing a class of impulsive systems. As a result, an on-line estimation of unknown parameters is provided, regardless of the switching times nor of the impulse rules. Numerical simulations of physical processes with noisy data are illustrating our methodology and results.
Automatique
