Multilingual Lexical Support for the SEMbySEM project. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper we describe how multilingual linguistic and lexical information is stored and accessed within the framework of the SEMbySEM project\footnote{SEMbySEM (\url{http://www.sembysem.org}) is a research project within the European ITEA2 programme (\url{http://www.itea2.org/}). It started June 2008 and will end December 2010.}. The SEMbySEM project is dedicated to defining tools and standards for the supervision and management of complex and dynamic systems by using a semantic abstract representation. To provide the project with multilingual linguistic and lexical information and in order to achieve an appropriate, flexible, reusable and accurate representation of this information we chose the Linguistic Information Repository representation \cite{NeOn08} model and adapted it to our needs. In this paper we discuss the rationale for this choice, describe its implementation and also the employment of other linguistic standards.
final.pdf (159.65 Ko) Télécharger le fichier
main.pdf (446.39 Ko) Télécharger le fichier
Format : Autre
inria-00509763 , version 1 (16-08-2010)
  • HAL Id : inria-00509763 , version 1
Ingrid Falk, Samuel Cruz-Lara, Nadia Bellalem, Tarik Osswald, Vincent Herrmann,. Multilingual Lexical Support for the SEMbySEM project.. LREC Workshop Language Resource and Technology Standards, May 2010, La Valetta, Malta. ⟨inria-00509763⟩
510 Consultations
315 Téléchargements
