Conference papers
A GPU-based Iterated Tabu Search for Solving the Quadratic 3-dimensional Assignment Problem
Thé Van Luong 1 Nouredine Melab 1 El-Ghazali Talbi 1
1 DOLPHIN - Parallel Cooperative Multi-criteria Optimization
LIFL - Laboratoire d'Informatique Fondamentale de Lille, Inria Lille - Nord Europe
Abstract : The quadratic 3-dimensional assignment problem (Q3AP) is an extension of the well-known NP-hard quadratic assignment problem. It has been proved to be one of the most difficult combinatorial optimization problems. Local search (LS) algorithms are a class of heuristics which have been successfully applied to solve such hard optimization problem. These methods handle with a single solution iteratively improved by exploring its neighborhood in the solution space. In this paper, we propose an iterated tabu search for solving the Q3AP. The design of this algorithm is essentially based on a new large neighborhood structure. Indeed, in LS heuristics, designing operators to explore large promising regions of the search space may improve the quality of the obtained solutions. However, designing such neighborhood is at the expense of a highly computationally process. Therefore, the use of graphics processing units (GPUs) provides an efficient complementary way to speed up the search. The proposed GPU-based iterated tabu search has been experimented on 5 different Q3AP instances. The obtained results are convincing both in terms of efficiency, quality and robustness of the provided solutions at run time.
Document type :
Conference papers
Complete list of metadata
Cited literature [23 references]  Display  Hide  Download
https://hal.inria.fr/inria-00520468
Contributor : Thé Van Luong Connect in order to contact the contributor
Submitted on : Thursday, September 23, 2010 - 12:57:58 PM
Last modification on : Thursday, January 20, 2022 - 5:27:49 PM
Long-term archiving on: : Friday, December 24, 2010 - 2:48:14 AM
File
POECE2010Paper.pdf
Identifiers
  • HAL Id : inria-00520468, version 1
Citation
Thé Van Luong, Nouredine Melab, El-Ghazali Talbi. A GPU-based Iterated Tabu Search for Solving the Quadratic 3-dimensional Assignment Problem. Workshop on Parallel Optimization in Emerging Computing Environments (POECE) in Conjunction with the International Conference on Computer Systems and Applications (AICCSA), 2010, Hammamet, Tunisia. ⟨inria-00520468⟩
Share
Metrics
Les métriques sont temporairement indisponibles
