Abstract : System-on-Chip (SoC) architectures are becoming the preferred solution for implementing modern embedded systems. However their design complexity continues to augment due to the increase in integrated hardware resources requiring new design methodologies and tools. In this paper we present a novel SoC co-design methodology based on aModel Driven Engineering framework while utilizing the MARTE (Modeling and Analysis of Real-time and Embedded Systems) standard. This methodology permits us to model fine grain reconfigurable architectures such as FPGAs and allows to extend the standard for integrating new features such as Partial Dynamic Reconfiguration supported by modern FPGAs. The overall objective is to carry out modeling at a high abstraction level expressed in a graphical language like UML (Unified Modeling Language) and afterwards transformations of these models, automatically generate the necessary specifications required for FPGA implementation.
https://hal.inria.fr/inria-00525008 Contributor : Mister DartConnect in order to contact the contributor Submitted on : Sunday, October 10, 2010 - 7:03:26 PM Last modification on : Friday, February 4, 2022 - 3:19:11 AM Long-term archiving on: : Tuesday, January 11, 2011 - 2:35:03 AM
