Critical Motion Sequences for the Self-Calibration of Cameras and Stereo Systems with Variable Focal Length - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1999
Peter Sturm
We consider the self-calibration problem for a moving camera whose intrinsic parameters are known, except the focal length, which may vary freely across different views. The conditions under which the determination of the focal length's values for an image sequence is not possible, are derived. These depend only on the camera's motions. We give a complete catalogue of the so-called critical motion sequences. This is then used to derive the critical motion sequences for stereo systems with variable focal lengths.
Sturm-bmvc99.pdf (144.33 Ko) Télécharger le fichier
inria-00525676 , version 1 (30-05-2011)
  • HAL Id : inria-00525676 , version 1
Peter Sturm. Critical Motion Sequences for the Self-Calibration of Cameras and Stereo Systems with Variable Focal Length. The 10th British Machine Vision Conference (BMVC '99), Sep 1999, Nottingham, United Kingdom. pp.63-72. ⟨inria-00525676⟩
149 Consultations
548 Téléchargements
