Resource allocation algorithms for virtualized service hosting platforms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Parallel and Distributed Computing Année : 2010
Commodity clusters are used routinely for deploying service hosting platforms. Due to hardware and operation costs, clusters need to be shared among multiple services. Crucial for enabling such shared hosting platforms is virtual machine (VM) technology, which allows consolidation of hardware resources. A key challenge, however, is to make appropriate decisions when allocating hardware resources to service instances. In this work we propose a formulation of the resource allocation problem in shared hosting platforms for static workloads with servers that provide multiple types of resources. Our formulation supports a mix of best-effort and QoS scenarios, and, via a precisely defined objective function, promotes performance, fairness, and cluster utilization. Further, this formulation makes it possible to compute a bound on the optimal resource allocation. We propose several classes of resource allocation algorithms, which we evaluate in simulation. We are able to identify an algorithm that achieves average performance close to the optimal across many experimental scenarios. Furthermore, this algorithm runs in only a few seconds for large platforms and thus is usable in practice.
paper.pdf (469.57 Ko) Télécharger le fichier
inria-00527066 , version 1 (21-10-2010)
Mark Stillwell, David Schanzenbach, Frédéric Vivien, Henri Casanova. Resource allocation algorithms for virtualized service hosting platforms. Journal of Parallel and Distributed Computing, 2010, 70 (9), pp.962-974. ⟨10.1016/j.jpdc.2010.05.006⟩. ⟨inria-00527066⟩
167 Consultations
903 Téléchargements
