Data assimilation for short range atmospheric dispersion of radionuclides : a case study of second-order sensitivity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Environmental Radioactivity Année : 2005
This article presents the application of variational data assimilation to a simple Gaussian plume model for radionuclides. Adjoint modeling is applied to the model in order to minimize discrepancies between contamination observations and model outputs. The interest of such an approach is to get a better estimation of some parameters such as emissions or dispersion parameters. A second-order analysis is also performed to assess the sensitivity of the optimized parameters to some poorly known parameters. Sensitivity with respect to network design is also done.
inria-00527208 , version 1 (18-10-2010)
Denis Quélo, Bruno Sportisse, Olivier Isnard. Data assimilation for short range atmospheric dispersion of radionuclides : a case study of second-order sensitivity. Journal of Environmental Radioactivity, 2005, 84-3, pp.393-408. ⟨10.1016/j.jenvrad.2005.04.011⟩. ⟨inria-00527208⟩
66 Consultations
0 Téléchargements
