Observability Normal Forms for a class of switched systems with zeno phenomena - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
This paper deals with necessary and sufficient conditions to transform a class of switched systems to a particular form dedicated to observer design with and without zeno phenomena. Meanwhile, sufficient observability conditions for switched system with or without zeno phenomena are given. In the last section, some observer structures are proposed upon two academical examples.
Automatique
Zeno_ACC09_vfin_.pdf (284.71 Ko) Télécharger le fichier
inria-00530116 , version 1 (27-10-2010)
  • HAL Id : inria-00530116 , version 1
Lei Yu, Jean-Pierre Barbot, Driss Boutat, Djamila Benmerzouk. Observability Normal Forms for a class of switched systems with zeno phenomena. 2009 American Control Conference, Jun 2009, St. Louis, Missouri, USA, United States. ⟨inria-00530116⟩
172 Consultations
191 Téléchargements
