Visualization of Practices and Metrics (Workpackage 1.2) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2010
Measuring applications is a challenge and one of the goal of the Squale project is to propose a sound quality model. Now presenting the results of such analysis is also a challenge since it is complex to output and present to the user for the following rea- sons: first a lot of data should be presented and at different audience. Second displaying information is one aspect another one is navigating the information. Finally it is im- portant not to overwhelm the users with too much visualizations. This workpackage presents a state of the art in terms of software visualization approaches that are specif- ically designed to display metrics. In addition it sets up the context for the application of such visualization to practices.
deliverable12.pdf (2.57 Mo) Télécharger le fichier
inria-00533618 , version 1 (08-11-2010)
  • HAL Id : inria-00533618 , version 1
Stéphane Ducasse, Simon Denier, Françoise Balmas, Alexandre Bergel, Jannik Laval, et al.. Visualization of Practices and Metrics (Workpackage 1.2). [Research Report] 2010, pp.56. ⟨inria-00533618⟩
181 Consultations
160 Téléchargements
