Processing Underspecified Semantic Representations in the Constraint Language for Lambda Structures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal on Research in Language and Computation Année : 2002
The constraint language for lambda structures (CLLS) is an expressive language of tree descriptions which combines dominance constraints with powerful parallelism and binding constraints. CLLS was introduced as a uniform framework for defining underspecified semantics representations of natural language sentences, covering scope, ellipsis, and anaphora. This article presents saturation-based algorithms for processing the complete language of CLLS. It also gives an overview of previous results on questions of processing and complexity.
processing00.pdf (858.54 Ko) Télécharger le fichier
inria-00536796 , version 1 (18-11-2010)
  • HAL Id : inria-00536796 , version 1
Katrin Erk, Alexander Koller, Joachim Niehren. Processing Underspecified Semantic Representations in the Constraint Language for Lambda Structures. Journal on Research in Language and Computation, 2002, 1 (1), pp.127--169. ⟨inria-00536796⟩
22 Consultations
137 Téléchargements
