Subdivision Invariant Polynomial Interpolation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
In previous works a polynomial interpolation method for triangular meshes has been introduced. This interpolant can be used to design smooth surfaces of arbitrary topological type. In a design process, it is very useful to be able to locate the deformation made on a geometric model. The previously introduced interpolant has the so-called strict locality property: when a mesh vertex is changed, only the surface patches containing this vertex are changed. This enables to locate the deformation at the size of the input triangles. Unfortunately this is not sufficient if the designer wants to add some detail at a smaller size than that of the input triangles. In this paper, we propose a modification of our interpolant, that enables to arbitrary refine the input triangulation, without changing the resulting surface. We call this property the subdivision invariance. After refinement of the input triangulation, the modification of one of the vertices will change the shape of the interpolant at the scale of the refined triangulation. In this way, it is possible to add details at an arbitrary fine scale.
paper-vismath2.pdf (937.99 Ko) Télécharger le fichier
Format : Figure, Image
inria-00537477 , version 1 (18-11-2010)
  • HAL Id : inria-00537477 , version 1
Stefanie Hahmann, Georges-Pierre Bonneau, Alex Yvart. Subdivision Invariant Polynomial Interpolation. International Workshop on Visalization and Mathematics (Vismath 2002 ), May 2002, Berlin-Dahlem, Germany. pp.191--202. ⟨inria-00537477⟩
301 Consultations
367 Téléchargements
