Smoothed Particles: A new paradigm for animating highly deformable bodies - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1996
This paper presents a new formalism for simulating highly deformable bodies with a particle system. Smoothed particles represent sample points that enable the approximation of the values and derivatives of local physical quantities inside a medium. They ensure valid and stable simulation of state equations that describe the physical behavior of the material. We extend the initial formalism, first introduced for simulating cosmological fluids, to the animation of inelastic bodies with a wide range of stiffness and viscosity. We show that the smoothed particles paradigm leads to a coherent definition of the object's surface as an iso-surface of the mass density function. Implementation issues are discussed, including an efficient integration scheme using individually adapted time steps to integrate particle motion. Animation requires a linear complexity in the number of particles, offering reasonable time and memory use.
SmoothedParticles.pdf (185.03 Ko) Télécharger le fichier
Format : Figure, Image
inria-00537534 , version 1 (18-11-2010)
  • HAL Id : inria-00537534 , version 1
Mathieu Desbrun, Marie-Paule Cani. Smoothed Particles: A new paradigm for animating highly deformable bodies. Eurographics Workshop on Computer Animation and Simulation (EGCAS), Aug 1996, Poitiers, France. pp.61--76. ⟨inria-00537534⟩
424 Consultations
1540 Téléchargements
