Regular Tree Languages and Rewrite Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Fundamenta Informaticae Année : 1995
We present a collection of results on regular tree languages and rewrite systems. Moreover we prove the undecidability of the preservation of regularity by rewrite systems. More precisely we prove that it is undecidable whether or not for a set E of equations the set E(R) congruence closure of set R is a regular tree language whenever R is a regular tree language. It is equally undecidable whether or not for a confluent and terminating rewrite system S the set S(R) of ground S-normal forms of set R is a regular tree language whenever R is a regular tree language. Finally we study fragments of the theory of ground term algebras modulo congruence generated by a set of equations which can be compiled in a terminating, confluent rewrite system which preserves regularity.
Fichier non déposé
inria-00538882 , version 1 (23-11-2010)
  • HAL Id : inria-00538882 , version 1
Rémi Gilleron, Sophie Tison. Regular Tree Languages and Rewrite Systems. Fundamenta Informaticae, 1995, 24 (1/2), pp.157--176. ⟨inria-00538882⟩
173 Consultations
0 Téléchargements
