New interface
Reports (Research report)
Uncertainty Quantification for Eigenvalue-Realization-Algorithm, A Class of Subspace System Identification
Xuan-Binh Lam 1 Laurent Mevel 1
1 I4S - Statistical Inference for Structural Health Monitoring
IFSTTAR/COSYS - Département Composants et Systèmes, Inria Rennes – Bretagne Atlantique
Abstract : In Operational Modal Analysis, the modal parameters (natural frequencies, damping ratios and mode shapes), obtained from Stochastic System Identication of structures, are subject to statistical uncertainty from ambient vibration measurements. It is hence necessary to evaluate the condence intervals of these obtained results. This paper will propose an algorithm that can eciently estimate the uncertainty on modal parameters obtained from the Eigensystem-Realization-Algorithm (ERA).
Complete list of metadata
https://hal.inria.fr/inria-00538941
Contributor : Laurent Mevel Connect in order to contact the contributor
Submitted on : Thursday, March 3, 2011 - 4:18:24 PM
Last modification on : Thursday, October 27, 2022 - 4:02:45 AM
Long-term archiving on: : Tuesday, November 6, 2012 - 3:10:57 PM
File
RR7462.pdf
Identifiers
  • HAL Id : inria-00538941, version 1
Citation
Xuan-Binh Lam, Laurent Mevel. Uncertainty Quantification for Eigenvalue-Realization-Algorithm, A Class of Subspace System Identification. [Research Report] RR-7462, INRIA. 2010, pp.16. ⟨inria-00538941⟩
Share
Metrics
Record views
150
Files downloads
242
