Comparing Workflow Specification Languages: A Matter of Views - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Serge Abiteboul
Pierre Bourhis
We address the problem of comparing the expressiveness of workflow specification formalisms using a notion of view of a workflow. Views allow to compare widely different workflow systems by mapping them to a common representation capturing the observables relevant to the comparison. Using this framework, we compare the expressiveness of several workflow specification mechanisms, including automata, temporal constraints, and pre-and-post conditions, with XML and relational databases as underlying data models. One surprising result shows the considerable power of static constraints to simulate apparently much richer workflow control mechanisms.
Fichier non déposé
inria-00539579 , version 1 (24-11-2010)
  • HAL Id : inria-00539579 , version 1
Serge Abiteboul, Pierre Bourhis, Victor Vianu. Comparing Workflow Specification Languages: A Matter of Views. International Conference on Database Theory (ICDT), Mar 2011, Uppsala, Sweden. ⟨inria-00539579⟩
247 Consultations
0 Téléchargements
