Conference papers
Smart distance keeping: modeling and perspectives for embedded diagnosis
Abstract : This paper presents a detailed description of an advanced Adaptive Cruise Control (ACC) system implemented on a Renault-Volvo Trucks vehicle. One of the main differences between this new system, which is called the Smart Distance Keeping (SDK), and the classical ACC is the choice of the safe distance. This later is the distance between the vehicle (with the ACC or the SDK system) and the front obstacle (which may be a vehicle). It is supposed fix in the case of the ACC, while variable in the case of the SDK. The variation of this distance (in the case of SDK) depends essentially on the relative velocity between the vehicle and the front obstacle. The choice of this distance influences the velocity regulation. The main contribution of this work is on the SDK system architecture, the design of its environment model, and the proposition of a detection and isolation strategy for some of the possible faults that may be produced on the system.
Complete list of metadata
Cited literature [10 references]  Display  Hide  Download
https://hal.inria.fr/inria-00540819
Contributor : Philippe Dague Connect in order to contact the contributor
Submitted on : Monday, November 29, 2010 - 11:56:59 AM
Last modification on : Sunday, June 26, 2022 - 11:52:41 AM
Long-term archiving on: : Saturday, December 3, 2016 - 12:51:41 AM
File
1569263909.pdf
Identifiers
  • HAL Id : inria-00540819, version 1
Collections
Citation
Hassan Shraïm, Othman Nasri, Philippe Dague, Olivier Héron, Mickael Cartron. Smart distance keeping: modeling and perspectives for embedded diagnosis. 1rst International Conference on Intelligent Systems, Modelling and Simulation ISMS'10, Jan 2010, Liverpool, United Kingdom. ⟨inria-00540819⟩
Share
Metrics
Record views
233
Files downloads
193
