Deploying Wireless Sensors for Differentiated Coverage and Probabilistic Connectivity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The deployment strategy for achieving differentiated coverage and probabilistic connectivity in wireless sensor networks is studied in this paper. A novel solution based on elitist non-dominated sorting genetic algorithm (NSGA-II) is proposed. Simulation results show that NSGA-II based strategy can meet the desired coverage requirements and maintain connectivity in a probabilistic manner with a relatively small number of sensors. In addition, for the applications in which the coverage requirement varies in some subareas, a local genetic operation is more time efficient and needs less variation in the original disposal than a renewed global optimization.
WCNC.pdf (259.24 Ko) Télécharger le fichier
inria-00541959 , version 1 (01-12-2010)
  • HAL Id : inria-00541959 , version 1
Yanjun Li, Ye-Qiong Song, Zhu Yi-Hua, René Schott. Deploying Wireless Sensors for Differentiated Coverage and Probabilistic Connectivity. IEEE Wireless Communications and Networking Conference - WCNC 2010, Apr 2010, Sydney, Australia. ⟨inria-00541959⟩
201 Consultations
313 Téléchargements
