New interface
Reports (Research report)
Throughput optimization for micro-factories subject to task and machine failures
Abstract : In this paper, we study the problem of optimizing the throughput for micro-factories subject to failures. The challenge is to map several tasks of different types onto a set of machines. The originality of our approach is the failure model for such applications in which not only the machines are subject to failures but the reliability of a task may depend on its type. The failure rate is unrelated: a probability of failure is associated to each couple (task type, machine). We consider different kind of mappings: in one-to-one mappings, each machine can process only a single task, while several tasks of the same type can be processed by the same machine in specialized mappings. Finally, general mappings have no constraints. The optimal one-to-one mapping can be found in polynomial time for particular problem instances, but the problem is NP- hard in most of the cases. For the most realistic case of specialized mappings, which turns out to be NP-hard, we design several polynomial time heuristics and a linear program allows us to find the optimal solution (in exponential time) for small problem instances. Experimental results show that the best heuristics obtain a good throughput, much better than the throughput achieved with a random mapping. Moreover, we obtain a throughput close to the optimal solution in the particular cases where the optimal throughput can be computed.
Document type :
Complete list of metadata
Cited literature [13 references]  Display  Hide  Download
https://hal.inria.fr/inria-00544146
Contributor : Anne Benoit Connect in order to contact the contributor
Submitted on : Tuesday, December 7, 2010 - 1:45:45 PM
Last modification on : Wednesday, October 26, 2022 - 8:16:49 AM
Long-term archiving on: : Monday, November 5, 2012 - 12:31:04 PM
File
RR-7479.pdf
Identifiers
  • HAL Id : inria-00544146, version 1
Citation
Anne Benoit, Alexandru Dobrila, Jean-Marc Nicod, Laurent Philippe. Throughput optimization for micro-factories subject to task and machine failures. [Research Report] RR-7479, INRIA. 2010. ⟨inria-00544146⟩
Share
Metrics
Record views
262
Files downloads
139
