Evaluation of Automatic Formant Tracking Method Using Fourier Ridges - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Cognitive Computation Année : 2010
This paper develops a formant tracking technique based on Fourier ridges detection. This work aims at improving the performance of formant tracking algorithms. In this method, we have introduced a continuity constraint based on the computation of the centre of gravity for a set of formant candidates, which leads to link a frame of speech with its neighbours and thus improves the robustness of tracking. The formant trajectories obtained by the algorithm proposed are compared with those of a hand edited formant Arabic database, created especially for this work, and those given by Praat with LPC data.
Linguistique
Fichier non déposé
inria-00544221 , version 1 (07-12-2010)
  • HAL Id : inria-00544221 , version 1
Imen Jemaa, Kais Ouni, Yves Laprie. Evaluation of Automatic Formant Tracking Method Using Fourier Ridges. Cognitive Computation, 2010, 2, pp.170-179. ⟨inria-00544221⟩
109 Consultations
0 Téléchargements
