Abstract : This article treats the problem of learning a dictionary providing sparse representations for a given signal class, via L1 minimisation. The problem is to identify a dictionary Phi from a set of training samples Y knowing that Y = Phi.X for some coefficient matrix X. Using a characterisation of coefficient matrices X that allow to recover any orthonormal basis (ONB) as a local minimum of an L1 minimisation problem, it is shown that certain types of sparse random coefficient matrices will ensure local identifiability of the ONB with high probability, for a number of training samples which essentially grows linearly with the signal dimension.
