The Common Log Format (CLF) for the Session Initiation Protocol (SIP) - draft-gurbani-sipclf-problem-statement-00 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 2010
Gurbani Vijay
  • Fonction : Auteur
Burger Eric
  • Fonction : Auteur
T. Anjali
  • Fonction : Auteur
Well-known web servers such as Apache and web proxies like Squid support event logging using a common log format. The logs produced using these de-facto standard formats are invaluable to system administrators for trouble-shooting a server and tool writers to craft tools that mine the log files and produce reports and trends. Furthermore, these log files can also be used to train anomaly detection systems and feed events into a security event management system. The Session Initiation Protocol does not have a common log format, and as a result, each server supports a distinct log format that makes it unnecessarily complex to produce tools to do trend analysis and security detection. We propose a common log file format for SIP servers that can be used uniformly by proxies, registrars, redirect servers as well as back-to-back user agents.
Fichier non déposé
inria-00546445 , version 1 (14-12-2010)
  • HAL Id : inria-00546445 , version 1
Gurbani Vijay, Burger Eric, T. Anjali, Humberto Abdelnur, Olivier Festor. The Common Log Format (CLF) for the Session Initiation Protocol (SIP) - draft-gurbani-sipclf-problem-statement-00. 2010. ⟨inria-00546445⟩
80 Consultations
0 Téléchargements
