New interface
Other publications
Deliverable D2.1 Closed loop fuzzing algorithms
Laurent Andrey 1, * Humberto Abdelnur 1 Jorge Lucangeli Obes 1 Olivier Festor 1 Radu State 2
* Corresponding author
1 MADYNES - Management of dynamic networks and services
INRIA Lorraine, LORIA - Laboratoire Lorrain de Recherche en Informatique et ses Applications
Abstract : The techniques and tools described in this report propose a way to measure the impact of a fuzzer on a running system. The work focuses on protocols fuzzing. So tested systems are protocol entities and inputs protocol messages. Therefore the elementary measure assesses the impact of a crafted protocol message injected into the running system under test. From this point several interesting uses can be derived: • The overall impact, the coverage of a sequence generated by a the fuzzer can be calculated. • Then two fuzzers can be compared. • One or several sequences can be optimized: only messages introducing the best coverage can be selected to limit the cost (duration) to apply the test. • The process, the strategy that generates sequences can itself take advantage of this impact measurement to directly produce new optimized sequences. The Session Initiation Protocol (SIP) is the target protocol of the study.
Document type :
Other publications
Complete list of metadata
Cited literature [35 references]  Display  Hide  Download
https://hal.inria.fr/inria-00546964
Contributor : Laurent Andrey Connect in order to contact the contributor
Submitted on : Wednesday, December 15, 2010 - 11:23:10 AM
Last modification on : Wednesday, February 2, 2022 - 3:51:49 PM
Long-term archiving on: : Monday, November 5, 2012 - 1:50:41 PM
File
ANR-08-VERS-017-d2-1.pdf
Publisher files allowed on an open archive
Identifiers
  • HAL Id : inria-00546964, version 1
Collections
Citation
Laurent Andrey, Humberto Abdelnur, Jorge Lucangeli Obes, Olivier Festor, Radu State. Deliverable D2.1 Closed loop fuzzing algorithms. 2010. ⟨inria-00546964⟩
Share
Metrics
Record views
134
Files downloads
357
