An Experience on Automatic Selection of the Edge Detectors
Summarizes a system, called SED 'selection of edge detectors', which is able to select automatically edge detectors and their scales to extract a given edge. To avoid a combinatorial approach, the authors use several sources of information like the characteristics of the given edge, the properties of the detectors and the mutual relations between them. The authors illustrate our approach by the study of an example.
