Abstract : The author gives geometric constructive solutions for 3-D vision problems like positioning a point in space from two views. Using reference points in the scene, no calibration is needed. The method involves only simple geometric computation. From the experiments it is concluded that positioning 3-D points relatively to reference points, is easy and provides more reliable results than absolute positioning as is usually done.
https://hal.inria.fr/inria-00548453 Contributor : THOTH TeamConnect in order to contact the contributor Submitted on : Tuesday, May 31, 2011 - 3:54:31 PM Last modification on : Friday, November 6, 2020 - 4:38:57 AM Long-term archiving on: : Thursday, September 1, 2011 - 2:21:02 AM
Roger Mohr, Luce Morin. Relative Positioning from Geometric Invariants. International Conference on Computer Vision & Pattern Recognition (CVPR '91), Jun 1991, Maui, United States. pp.139--144, ⟨10.1109/CVPR.1991.139676⟩. ⟨inria-00548453⟩
