Learning to recognize objects with little supervision - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Computer Vision Année : 2008
This paper shows (i) improvements over state-of-the-art local feature recognition systems, (ii) how to formulate principled models for automatic local feature selection in object class recognition when there is little supervised data, and (iii) how to formulate sensible spatial image context models using a conditional random field for integrating local features and segmentation cues (superpixels). By adopting sparse kernel methods, Bayesian learning techniques and data association with constraints, the proposed model identifies the most relevant sets of local features for recognizing object classes, achieves performance comparable to the fully supervised setting, and obtains excellent results for image classification.
inria-00548668 , version 1 (20-12-2010)
Peter Carbonetto, Gyuri Dorkó, Cordelia Schmid, Hendrik Kück, Nando de Freitas. Learning to recognize objects with little supervision. International Journal of Computer Vision, 2008, 77 (1-3), pp.219-238. ⟨10.1007/s11263-007-0067-7⟩. ⟨inria-00548668⟩
187 Consultations
0 Téléchargements
