Efficient sampling of RNA secondary structures from the Boltzmann ensemble of low-energy: The boustrophedon method - Archive ouverte HAL Access content directly
Journal Articles Journal of Mathematical Biology Year : 2008
We adapt here a surprising technique, the boustrophedon method, to speed up the sampling of RNA secondary structures from the Boltzmann low-energy ensemble. This technique is simple and its implementation straight-forward, as it only requires a permutation in the order of some operations already performed in the stochastic traceback stage of these algorithms. It nevertheless greatly improves their worst-case complexity from O(n^2) to O(n log(n)), for n the size of the original sequence. Moreover the average-case complexity of the generation is shown to be improved from O(n√n) to O(n log(n)) in an Boltzmann-weighted homopolymer model based on the Nussinov–Jacobson free-energy model. These results are extended to the more realistic Turner free-energy model through experiments performed on both structured (Drosophilia melanogaster mRNA 5S) and hybrid (Staphylococcus aureus RNAIII) RNA sequences, using a boustrophedon modified version of the popular software UnaFold. This improvement allows for the sampling of greater and more significant sets of structures in a given time.
Dates and versions
inria-00548863 , version 1 (20-12-2010)
Identifiers
Cite
Yann Ponty. Efficient sampling of RNA secondary structures from the Boltzmann ensemble of low-energy: The boustrophedon method. Journal of Mathematical Biology, 2008, 56 (1-2), pp.107--127. ⟨10.1007/s00285-007-0137-z⟩. ⟨inria-00548863⟩
130 View
0 Download
Share
