Abstract : In this chapter, image-based visual servoing is addressed via nonlinear model predictive control. The visual servoing task is formulated into a nonlinear optimization problem in the image plane. The proposed approach, named visual pre- dictive control, can easily and explicitly take into account 2D and 3D constraints. Furthermore, the image prediction over a finite prediction horizon plays a crucial role for large displacements. This image prediction is obtained thanks to a model. The choice of this model is discussed. A nonlinear global model and a local model based on the interaction matrix are considered. Advantages and drawbacks of both models are pointed out. Finally, simulations obtained with a 6 degrees of freedom (DOF) free-flying camera highlight the capabilities and the efficiency of the pro- posed approach by a comparison with the classical image-based visual servoing.
https://hal.inria.fr/inria-00548935
Contributor : Eric Marchand <>
Submitted on : Monday, December 20, 2010 - 10:01:51 PM Last modification on : Thursday, January 7, 2021 - 4:15:56 PM Long-term archiving on: : Monday, March 21, 2011 - 3:45:57 AM
Guillaume Allibert, Estelle Courtial, F. Chaumette. Visual servoing via Nonlinear Predictive control. Chesi, G. and Hashimoto, K. Visual Servoing via Advanced Numerical Methods, LNCIS 401, Springer-Verlag, pp.375--394, 2010. ⟨inria-00548935⟩
