An introduction to linear and cyclic codes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2009
Our purpose is to recall some basic aspects about linear and cyclic codes. We first briefly describe the role of error-correcting codes in communication. To do this we introduce, with examples, the concept of linear codes and their parameters, in particular the Hamming distance. A fundamental subclass of linear codes is given by cyclic codes, that enjoy a very interesting algebraic structure. In fact, cyclic codes can be viewed as ideals in a residue classes ring of univariate polynomials. BCH codes are the most studied family of cyclic codes, for which some efficient decoding algorithms are known, as the method of Sugiyama.
introcyclic-springer.pdf (244.8 Ko) Télécharger le fichier
inria-00550061 , version 1 (23-12-2010)
Daniel Augot, Emmanuela Orsini, Emanuele Betti. An introduction to linear and cyclic codes. Sala, Massimiliano and Mora, Teo and Perret, Ludovic and Sakata, Shojiro and Traverso, Carlo. Gröbner Bases, Coding, and Cryptography, Springer-Verlag, pp.47-68, 2009, Gröbner Bases, Coding, and Cryptography, ⟨10.1007/978-3-540-93806-4_4⟩. ⟨inria-00550061⟩
Collections
INRIA INRIA2
199 Consultations
2664 Téléchargements
