New interface
Conference papers
Extension des segments flous aux images en niveaux de gris pour l'extraction interactive de segments de droites
Philippe Even 1 Bertrand Kerautret 1
1 ADAGIO - Applying Discrete Algorithms to Genomics and Imagery
LORIA - Laboratoire Lorrain de Recherche en Informatique et ses Applications
Abstract : The recognition of discrete straight segments is a significant topic in the field of discrete geometry and for many applications dealing with geometric feature extraction. It can be performed from noisy binary data using the concept of blurred segments [3,2]. However, to our best knowledge, these algorithms have never been defined to directly extract straight segments in gray level images. This article proposes a solution to extend the recognition by using gray level image information. Although initially intended to be implemented within a semi-automatic line selec- tion tool used in an interactive 3D modeling application, it also meets more general parameter extraction requirements.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/inria-00551048
Contributor : Bertrand Kerautret Connect in order to contact the contributor
Submitted on : Sunday, January 2, 2011 - 10:42:45 AM
Last modification on : Friday, February 26, 2021 - 3:28:08 PM
Long-term archiving on: : Sunday, April 3, 2011 - 2:29:57 AM
File
main.pdf
Identifiers
  • HAL Id : inria-00551048, version 1
Collections
Citation
Philippe Even, Bertrand Kerautret. Extension des segments flous aux images en niveaux de gris pour l'extraction interactive de segments de droites. 17e Congrès Francophone AFRIF-AFIA Reconnaissance des Formes et Intelligence Artificielle - RFIA 2010, Jan 2010, Caen, France. ⟨inria-00551048⟩
Share
Metrics
Record views
111
Files downloads
94
