PASSAGE Syntactic Representation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
We present the PASSAGE syntactic representation based on syntactic relations, ini- tially developed for French in the scope of national evaluation campaigns. After a brief presentation of the non-nested chunks and syntactic relations of PASSAGE, we reuse the comparison elements that Marneffe and Manning have selected to compare the Standford typed dependencies (SD) against the GR and PARC representations, and show that PAS- SAGE is for a large part compatible compatible with these representation, standing closer to GR than to SD. After a presentation of the collaborative software support for PASSAGE representation, we conclude on some essential characteristics that pivot representation for syntax should exhibit.
Fichier non déposé
inria-00553256 , version 1 (06-01-2011)
  • HAL Id : inria-00553256 , version 1
Patrick Paroubek, Éric Villemonte de La Clergerie, Sylvain Loiseau, Anne Vilnat, Gil Francopoulo. PASSAGE Syntactic Representation. The 7th International Workshop on Treebanks and Linguistic Theories (TLT 2009), 2009, Groningen, Netherlands. ⟨inria-00553256⟩
139 Consultations
0 Téléchargements
