Mining Conceptual Graphs for Knowledge Acquisition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
This work addresses the use of computational linguistic anal- ysis techniques for conceptual graphs learning from unstruc- tured texts. A technique including both content mining and interpretation, as well as clustering and data cleaning, is introduced. Our proposal exploits sentence structure in or- der to generate concept hypothese, rank them according to plausibility and select the most credible ones. It enables the knowledge acquisition task to be performed without su- pervision, minimizing the possibility of failing to retrieve information contained in the document, in order to extract non-taxonomic relations.
Fichier non déposé
inria-00553518 , version 1 (07-01-2011)
Milagro Fernández Gavilanes, Éric Villemonte de La Clergerie, Manuel Vilares Ferro. Mining Conceptual Graphs for Knowledge Acquisition. ACM CIKM Workshop on Improving Non-English Web Searching : inews'08, Oct 2008, Napa Valley, CA, United States. pp.25--32, ⟨10.1145/1460027.1460032⟩. ⟨inria-00553518⟩
49 Consultations
0 Téléchargements
