Conference papers
A Case Study Of The Stochastic Modeling Approach For Range Estimation
Abstract : The floating-point to fixed-point conversion is an important part of the hardware design in order to obtain efficient implementations. In order to optimize the integer word-length under performance constraints, the dynamic variations of the variables during execution must be determined. Traditional range estimation methods based on simulations are data dependent and time consuming whereas analytical methods like interval and affine arithmetic give pessimistic results as they lack of a statistical background. Recently, a novel approach, based on the Karhunen-Loève Expansion (KLE) was presented for linear time-invariant (LTI) systems offering a solid stochastic foundation. Our paper presents an implementation of this theory and shows its efficiency for an OFDM modulator test case study. We also present a review of the uncertainty quantifications problem and the different phases of the range estimation methodology.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/inria-00554268
Contributor : Emmanuel Casseau Connect in order to contact the contributor
Submitted on : Monday, January 10, 2011 - 3:33:39 PM
Last modification on : Tuesday, October 19, 2021 - 11:58:51 PM
Identifiers
  • HAL Id : inria-00554268, version 1
Citation
Andrei Banciu, Emmanuel Casseau, Daniel Menard, Thierry Michel. A Case Study Of The Stochastic Modeling Approach For Range Estimation. Design and Architectures for Signal and Image Processing, Oct 2010, Edinburgh, United Kingdom. pp.301-308. ⟨inria-00554268⟩
Share
Metrics
Les métriques sont temporairement indisponibles
