Unanticipated Partial Behavioral Reflection - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Dynamic, unanticipated adaptation of running systems is of interest in a variety of situations, ranging from functional upgrades to on-the-fly debugging or monitoring of critical applications. In this paper we study a particular form of computational reflection, called unanticipated partial behavioral reflection, which is particularly well-suited for unanticipated adaptation of real-world systems. Our proposal combines the dynamicity of unanticipated reflection, i.e., reflection that does not require preparation of the code of any sort, and the selectivity and efficiency of partial behavioral reflection. First, we propose unanticipated partial behavioral reflection which enables the developer to precisely select the required reifications, to flexibly engineer the metalevel and to introduce the meta behavior dynamically. Second, we present a system supporting unanticipated partial behavioral reflection in Squeak Smalltalk, called Geppetto, and illustrate its use with a concrete example of a Seaside web application. Benchmarks validate the applicability of our proposal as an extension to the standard reflective abilities of Smalltalk.
Roet07bUPBReflection.pdf (222.29 Ko) Télécharger le fichier
inria-00555650 , version 1 (14-01-2011)
David Roethlisberger, Marcus Denker, Éric Tanter. Unanticipated Partial Behavioral Reflection. 14th International Smalltalk Conference (ISC 2006), ESUG, Sep 2006, Prag, Czech Republic. pp.47-65, ⟨10.1007/978-3-540-71836-9_3⟩. ⟨inria-00555650⟩
Collections
PHARO
38 Consultations
127 Téléchargements
