High Level Loop Transformations for Multidimensional Signal Processing Embedded Applications
Calin Glitia 1, 2 Pierre Boulet 1, 2, *
* Auteur correspondant
2 DART - Contributions of the Data parallelism to real time
LIFL - Laboratoire d'Informatique Fondamentale de Lille, Inria Lille - Nord Europe
Abstract : Array-OL specification model is a mixed graphical-textual language designed to model multidimensional intensive signal processing applications. Data and task parallelism are specified directly in the model. High level transformations are defined on this model, allowing the refactoring of an application and furthermore providing directions for optimization. The resemblances between with the wide-known and used Loop transformations lead us to try taking concepts and results from this domain and see how they fit in Array-OL context.
Type de document :
Communication dans un congrès
International Symposium on Systems, Architectures, MOdeling, and Simulation (SAMOS VIII), 2008, Samos, Greece. 2008
Liste complète des métadonnées
https://hal.inria.fr/inria-00565154
Contributeur : Pierre Boulet <>
Soumis le : vendredi 11 février 2011 - 10:35:01
Dernière modification le : jeudi 21 février 2019 - 10:52:49
  • HAL Id : inria-00565154, version 1
Collections
Citation
Calin Glitia, Pierre Boulet. High Level Loop Transformations for Multidimensional Signal Processing Embedded Applications. International Symposium on Systems, Architectures, MOdeling, and Simulation (SAMOS VIII), 2008, Samos, Greece. 2008. 〈inria-00565154〉
Métriques
Consultations de la notice
107
