Abstract : This work presents an approach for signal/image denoising in a semi-parametric frame. Our model is a wavelet-based one, which essentially assumes a minimal local regularity. This assumption translates into constraints on the multifractal spectrum of the signals. Such constraints are in turn used in a Bayesian framework to estimate the wavelet coefficients of the original signal from the noisy ones. Our scheme is well adapted to the processing of irregular signals, such as (multi-)fractal ones, and is potentially useful for the processing of e.g. turbulence, bio-medical or seismic data.
