New interface
Journal articles
Some Remarks on Nonlinear Approximation with Schauder Bases
Rémi Gribonval 1, 2 Morten Nielsen 2
1 METISS - Speech and sound data modeling and processing
IRISA - Institut de Recherche en Informatique et Systèmes Aléatoires, Inria Rennes – Bretagne Atlantique
Abstract : We study the approximation classes A_s^\alpha and G_s^\alpha associated with nonlinear m-term approximation and greedy approximation by elements from a quasi-normed Schauder basis in a separable Banach space. We show that there is always a two-sided embedding K_s^\tau_p \hookrightarrow A_s^\alpha \hookrightarrow K_s^\tau_q, where K_s^\tau denotes the associated smoothness space. We provide estimates of \tau_p and \tau_q in terms of quantitative properties of the basis. The lower and upper estimates are sharp for so-called quasi-greedy bases, but may not coincide with each other to completely characterize A_s^\alpha. For a quasi-greedy and democratic basis, a complete characterization G_s^\alpha = K_s^1/\alpha(w) is obtained where w is a weight depending on the properties of the basis. For greedy bases, G_s^\alpha = A_s^\alpha but the converse is not true. The results in this paper can be considered a generalization of the characterization for an orthonormal basis B in a Hilbert space H, where is it well known that A_s^\alpha(B) = K_s^\tau(B), with \alpha = 1/\tau-1/2 and s \in (0,\infty].
Complete list of metadata
https://hal.inria.fr/inria-00576640
Contributor : Rémi Gribonval Connect in order to contact the contributor
Submitted on : Tuesday, March 15, 2011 - 9:24:24 AM
Last modification on : Saturday, November 19, 2022 - 3:43:05 AM
Identifiers
  • HAL Id : inria-00576640, version 1
Citation
Rémi Gribonval, Morten Nielsen. Some Remarks on Nonlinear Approximation with Schauder Bases. East journal on approximations, 2001, 7 (3), pp.267-285. ⟨inria-00576640⟩
Share
Metrics
Record views
60
