An MDE-based approach for solving configuration problems: An application to the Eclipse platform
Abstract : Most of us have experienced configuration issues when installing new software applications. Finding the right configuration is often a challenging task since we need to deal with many dependencies between plug-ins, components, libraries, packages, etc; sometimes even regarding specific versions of the involved artefacts. Right now, most configuration engines are adhoc tools designed for specific configuration scenarios. This makes their reuse in different contexts very difficult. In this paper we report on our experience in following a MDE-based approach to solve configuration problems. In our approach, the configuration problem is represented as a model that abstracts all irrelevant technological details and facilitates the use of generic (constraint) solvers to find optimal solutions. This approach has been applied by an industrial partner to the management of plug-ins in the Eclipse framework, a big issue for all the technology providers that distribute Eclipse-based tools.
Type de document :
Communication dans un congrès
ECMFA 2011 - Seventh European Conference on Modelling Foundations and Applications, Jun 2011, Birmingham, United Kingdom. 2011
Liste complète des métadonnées
Littérature citée [10 références]  Voir  Masquer  Télécharger
https://hal.inria.fr/inria-00582506
Contributeur : Guillaume Doux <>
Soumis le : mercredi 15 juin 2011 - 14:02:36
Dernière modification le : jeudi 7 février 2019 - 16:51:06
Document(s) archivé(s) le : dimanche 4 décembre 2016 - 03:26:32
Fichier
An_MDE-based_approach_for_solv...
Fichiers produits par l'(les) auteur(s)
  • HAL Id : inria-00582506, version 1
Citation
Guillaume Doux, Patrick Albert, Gabriel Barbier, Jordi Cabot, Marcos Didonet del Fabro, et al.. An MDE-based approach for solving configuration problems: An application to the Eclipse platform. ECMFA 2011 - Seventh European Conference on Modelling Foundations and Applications, Jun 2011, Birmingham, United Kingdom. 2011. 〈inria-00582506〉
Métriques
Consultations de la notice
420
Téléchargements de fichiers
254
